Why do In Place Voids sometimes not cut
    This has always been a mystery to me. Sometimes I can get in place voids to cut and sometimes I can't. For instance here is a generic void that will not cut out the second floor ceiling above the stairs, but I can use a similar void to cut out the first floor ceiling. Why does this happen?
    Are you using Cut Geometry after creating the void?
      Hi Steve! I sure am using cut geometry. When it doesn't work, the items I am trying to select with the cut geometry tool wont select.
