Contour Problems
This topic is closed.
    Contour Problems
    Hey hey, I never had this problem untill I started working at a new company & the plans are colour shaded.
    Now how can I changed the contour labels masking colour?? I just hate the white blocks going all over. The fact that the labels are upside down don't even bother me as much as the white masking. (If you know how to change the upside down text, that would be good to know too)
    life's good :wine:
    simone allers
    senior draftsman
    Envisage Design Group
    I don't actually know what you mean but this should work (as it does for all annotation labels):
    Select the label, go to the Type Properties. Find out what the Annotation Family is, look it up in the Project Browser, right-click and open the Family. Select the label and turn the from Opaque in Transparant (probably also in Type Properties). Save Family and reload in Project.
    EDIT: Could you post a printscreen of the upside-down text?
      ...(If you know how to change the upside down text, that would be good to know too)
      I am pretty certain you are stuck with the upside down text. :banghead: :banghead:
        i've uploaded an image of what i mean. you'll notice it immediately, the red text with white masking around. I want the white to be changed to grey.
        life's good :wine:
        simone allers
        senior draftsman
          It looks like in your contour label family the "Keep Readable" option is not check. The white box might be something you are stuck with. Try changing the lable type to "transparent" and reloading it onto your project.
          -Alex Cunningham
            That all good Alex, but where do I find all these options as they aren't in the Element Properties and Contour Labels is not under Family in the Project Browser?
            life's good :wine:
            simone allers
            senior draftsman
              I believe that the contour label is a system family that cant be modified.
              At least I have not found a way to change those options
              Juan Carlos Moreno
              Sisley Cosmetics
                It's a system family, so you are stuck with the parameters under type properties. :banghead: You may however change the transparency with the element override. I hope that helps.
                  Yessir. Consistantly Inconsistant, hehehehe.
                    It sure would be nice if they ever decided to address all the little inconsistencies.
