When you draw two seperate walls back to back with each other, put a window in one and the opening only goes through the host... Okay I got that part. So I join them so the opening in the window goes through both walls. Now after joining them I can't dimension to the plane or surface where they are "joined" at.
I even tried this in an OOTB Revit template thinking that it might have something to do with my drawing but I got the same result. :banghead::banghead:
Anyone know if there is a way around this besides drawing a detail line at that plane so that I can dimension to it or is it just a Revit bug??
Thanks.
Thanks.
