I can set the "far clipping" but I don't see a way with view templates to be able to set the "far clip setting" (same as parent/Independent) and the ability to set the "far clip offset". Is there a way I can set this for certain views without having to go into each view and change this manually?
View templates that set options in the "extents" header
My top-rated new addition to Revit 2013 is the ability to create different view types, assign a view template and be able to make them dependent on it....
Channel: Blog Feeds
July 28, 2012, 10:15 PM -
Anyone know how to make my filters from my plan view work in a 3D view or section view.
I'm talking about colours, lines, patterns etc that...-
Channel: MEP - General
May 19, 2014, 01:02 PM -
Revit 2013 allows the user to assign a view template to each view. Initially I thought this was a good idea. Working with it I realized that values that...April 6, 2012, 09:42 PM
Hey Guys.
I'm currently working on setting up my own template. Right now I'm setting up the project browser. I got it all set up and it...October 26, 2014, 04:11 PM -
If your Manage View Templates button is disabled it means that you've got no view templates to manage. That troublemaker "someone" deleted them...
Channel: Blog Feeds
March 6, 2013, 03:15 PM -
