Applies to: - All Verticals
New Feature / Problem:
Make shapehandles on slab in section to control position.
Why do you need this Feature / Why is it a Problem:
When you're working in a section and you want to change the edge of the floor, you need to:
-go to floorplan
-select the slab
-edit the sketch
-zoom
-use allign or move to change the floorsketch
When you can use the shapehandle in section, it's only 1 action
Workflow:
See above
Benefits:
Saving time when modelling
Attachment comments:
-go to floorplan
-select the slab
-edit the sketch
-zoom
Workflow:
See above
Benefits:
