In a coarse display plan view, my filled New walls are obscured when they cross the path of a Demolished wall - if the demolished wall was created first. How can this be resolved?
In our plan views we want to see the Existing, the New and the Demolished so my Phase Filter is set to Show All.
Our Phasing Graphic Override has been set to hide the Demolished Cut Pattern so we just see dotted lines to indicate demolished walls.
If my existing walls are created after the new walls then they display correctly.
All the demolished walls obscure the floor pattern, which I don't want.
With Visual Sytle set to Shaded we get the full red demolished walls, which I don't want.
I've tried using VG and playing with the Phasing Graphic Overrides including setting the Demolished Material to Glass without luck.
Can anyone suggest how to make the cut view of a demolished wall show transparent? Or are there any other options please?
Thanks in advance.
Anthony.
Thanks in advance.
Anthony.
