Hi i wonder if we can make hole in toposurface just like floor because i have underground floor that is withing site ?
can we make hole in toposurface just like floor ?
Thanks,I tried Pad before asking but it is not working it makes a solid separate surface and if you delete it = you come back to the old complete surface.
split surface works now.Last edited by ahmed_hassan; November 3, 2011, 06:17 PM.
Hello every one.
I need some help. I am trying to find the best practice of applying fencing to a topographic surface I use railing all...March 10, 2011, 05:09 PM -
Hello Everyone,
I was wandering is it best to split a topo surface or use the building pad option or does it matter?
Thanks
...January 26, 2012, 03:24 PM -
hi all,
How to make a void in topography surface..?March 26, 2019, 05:41 AM -
Is there a way to only have the lines created from a sub-region on a topo, rather than a surface?
thank you,June 15, 2017, 05:00 AM -
I thought I should share this thread with you lot as I did a little dance when I stumbled onto it (If you already know this one, sit back with your pop...
Channel: Tutorials, Tips & Tricks
March 9, 2011, 10:26 AM -
