Revit 2011 - Modify tab has moved
    My modify tab has moved to the first tab on the ribbon and is now stuck there and I cannot figure out how to move it back to its original position.
    Solution:
    Click on it while holding down the control key and move to where you want it.
    Thanks to Darryl PRP & shiner79 in this thread for both the Q & A :thumbsup:
    I'm sure there's an option somewhere for default behaviour, but f... me if i can find it now...:banghead:
      To reset the ribbon and QAT to defaults follow the instructions here: http://docs.autodesk.com/REVIT/2011/...23bbb-3e2d.htm
      Erik
      Erik Snell, P.E.
      Factory Worker (Principal User Experience Designer)
      I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
        I had this problem before too. Hold down CTRL + drag where you want to move the tab to.
        Chad Koscinski | Architect
          Fantastic! Just ran into this problem, and what do you know, RFO has the answer :beer:
            Kim, you sound surprised! :laugh:
            Dan
              Not at all Dan. I was about to make a new topic about the exact same thing, but did a search first.. Then I still wanted to post something, just to keep it going
                Yeah, with me the entire bar is screwed up. No matter what I try to set it straight. When I reopen Revit the entire sorting is gone mad again... MAD I TELL YOU!!! :banghead:
                I gave up and am patiently awaiting 2013...
