I have a project where the floor is sloping. The floor has slab and band beams (structural framing), both the same material. Unfortunately, I do not see the hidden line for the step in the soffit when the floor is sloped. I can see they are joined in section.
I am assuming that because the dashed line representing the step in soffit is at an angle, the dashes 'merge' due to the point of view of the plan (hope that makes sense).
Now i know i can use linework to override this, but the plan is split into 4 dependant views due to its size, and there are three of each dependant (one for the GA, one for Top Reo, and one for Bott Reo). So it would be quite a task to do linework for all those sheets.
So, any ideas to get my linework to show?
The other issue, with the sloping band beam, I cannot get the end of the sloped beam to be vertical, the ends are perpendicular to the top and bottom of the band beam
I've attached a sample file if anyone would care to look.
Thanks in advance.
Thanks in advance.
