We have a central file with the revit structural model linked in. On 1 machine out of 5 a beam in a section view is lower than it should be. The other 4 machines/local files show it correct. Tried reloaded structural link, delete local and create new local and both didn't fix the issue. anyone had this issue or a fix?
structural link shows up different
Open the Central on the machine in question and check create new local. Upon opening, STC, and save locally. Try using "reload from" under Manage Links.
Make sure the Path under Manage Links is set to "absolute" as well, and that the path is EXACTLY correct. It just sounds like to one machine is a little "out of synch" will the others as and needs to be "refreshed/updated" via the Central File and the path to the link.
As a last resort, try REMOVING the Link altogether, re-link it and then have everyone STC.
Also make sure that machine is using the same build as the other machines.Cliff B. Collins
Registered Architect
Autodesk Expert Elite
any side effect of linking new RVT to my local instead of central? or should i ask everybody to stop working & close their local file until i linked...February 29, 2012, 04:07 PM
Hello All!!!
I am new to the Revit Forum and wanted to through out a question.
I'm sorry if this has already been posted,...May 4, 2011, 11:49 PM -
I've been trying to uncover a concise, procedural method to establish local aliases in a local copy of a workshared project that has network files linked...
Channel: Worksharing and Cloud Coordination
December 6, 2013, 07:01 PM -
EDIT Whoops.
Anyone know why I keeps getting the following message; "The Central model does not exist at the path you provided. The...October 28, 2013, 09:00 AM -
one of our users' computer have this issue, at first i thought it's Revit problem so we reinstalled Revit, but still not working.
we had...-
October 25, 2011, 04:09 PM -
