Can this stair be done in one stair sketch? I did this with 3 separate sketches...one for each stair run. The main problem I have is that I can't get stairs to have both an up and a down run in the same sketch.
Up and down stair runs in one sketch?
Well I'm struggling with Revit 2018.3, there are a lot of things going bad since I've started to use it, today Stairs by sketch don't want to work at...July 4, 2018, 12:44 PM
Hai,
How can we create stair using with stair calculator?January 9, 2012, 08:09 AM -
Good morning every one
, i have question for creating a little steps stair that have 3 sided shape what is the best tool i can use to create this little...
September 19, 2011, 07:59 AM -
Which type of stairs do you prefer to use? Stair by component or stair by sketch? What are good and bad sides of both? I noticed that when I use Stair...May 6, 2014, 03:16 PM
Guys,
For our construction process we use precast stairs. In this particular case we are not only creating the precast 'main stair flight',...April 17, 2013, 11:57 PM
