i have a building that all of the walls are pretty much in-place masses. The square footage right now is at 3000 and i need it about 10,000, is there anyway to scale up the whole building since i massed everything? thanks
Scaling up walls
No, there´s no easy way to do that... You should have made a conceptual mass, loaded it to the project, and applied the walls on the mass surface... Then you could just have scaled the mass, and updated the walls with a few clicks...
Welcome to the forum BTW! :beer:Klaus Munkholm
You might try:
Highlight the in-place Mass, then select Edit-in Place.
Highlight the Mass, and then choose edit extrusion ( or whatever you used to create the Mass)
Once in "sketch mode", select the Model or Reference Lines for the sketch, and then scale them up.
Finish sketch, finish family. Done.Cliff B. Collins
Registered Architect
Autodesk Expert Elite
Good point Cliff. But the way I read it, the entire building is made up with a lot of in-place walls, which would make that process rather painfull
Adesk! Could you please remove the In-place function in 2013? Or even better, replace it with a tilted wall tool?Klaus Munkholm
Hello again ...
I had to post it again!!! NOBODY KNOWS THE ANSWEAR GUYS???????????????????????????????????
I want to join a...April 19, 2012, 07:04 PM -
I created an in-place mass where I joined 3 masses. I want to create walls-by-face in order to schedule this object, but when I attempt it, revit creates...August 1, 2017, 05:13 PM
so i created voids in order to get the shape i want, i understand the underlay of the mass is a solid but is there a way to hollow it? to get rid of those...March 26, 2014, 12:20 AM
So my intent is to use in place mass for representing existing walls with varying sizes from the site survey for a project that will be demo'd later....May 24, 2017, 08:46 PM
Is it possible for the ends of walls to flex with a mass, rather than their face? Eg. attached, where the wall is perpendicular to the mass surface which...March 3, 2012, 06:26 PM
