Im just looking thru setting up 1:5 details from the model, using callouts from my larger 1:100 sections. I can vertically dimension the horizontal lines i.e. thickness of screed, then insulation, then slab etc, using the aligned dimension. But, I cannot get a dim on the vertical elements, i.e. wall thickness, plaster finish.
I can however, dim to a detail item like a skirting element...? Are there special rules regarding dims for these details..? I imagine that the linear ones maybe dont work because its a section,..?
Any pointers greatly received..
Cheers
Cheers
