Ive noticed a bug with linebased families when using a double horizontal flip control (or the spacebar). If you use the flip control within a project and then use the align command the family completely blows up.
Try it and you will see what I mean (Ive uploaded a simple one to test)
(Note that if you use the mirror command it works as expected) - anyone found a solution or should I report it as a bug?
