Swapping TBLKS - How to Mask by wildcards in Sheet Number
    I have a time-sensitive task - to search through a 500+ sheet file and swap titleblocks based on a factor in the Sheet Number.
    I've checked out Paul Wintour's 2017 script: https://parametricmonkey.com/2016/01...-family-types/ which got me to where I am now, which is a roadblock on the Boolmask:
    Is there an updated method that I'm unaware of?
    If I continue on this current method, can wildcards be used for a boolmask? Perhaps my syntax is the issue...
    Seem to have gotten one step further - no errors on the string for the Boolmask, however the output is still the full list, so the mask isn't working (yet)...
      Do you want to swap out your String.StartsWith with a String.Contains?
        [ATTACH=CONFIG]40200[/ATTACH]
        Am I missing why you need the Keys at all? I would get Sheet Numbers and do a String Contains -H-, then the Filter by book mask from that. Should work without the Sort by Keys, unless that's doing something else.
          Thanks Kraftwerk and Twiceroadsfool - both good tips. I'm going to try without the KEYS section, and see how that goes! thanks!
            I was on my phone, when i wrote the last comment. Here is the crude version:
              Also in that Code Block, you want to remove the * from the search.
