NonicaTab v3.0 released. Dynamo scripts as Revit buttons
    Hi Dynamo mates,
    I have just released NonicaTab v3.10 Add-In.
    NonicaTab v3.10 creates a new Revit toolbar with 12 Revit buttons that can easily be customized with your Dynamo scripts and favorite icons.
    There have been significant improvements in this new version. Each button has now a Set up Script and Set up Icon buttons to easily browse for your .dyn and .png files.
    For each button, either you can select one of the 55 Nonica included icons or your own icon (must be PNG and 32x32).
    Scripts and icons update at runtime.
    Check it out at https://nonica.io/
    Gave this a try because all the Dynamo toolbars I have seen and tried so far are pretty complicated to setup.
    This works very simple and for the graph I used it with pretty fast as well.
      Ive tried it also but only got 1 basic script hooked up so far :laugh:
      Would love drop down menus on each button to allow access to more than 12 scripts as i tend to sort mine by category / use case.
      Also, the installer asks for a specific revit version for the installation path, i changed it to 2019 and it installed for 2020 as well. Dunno how that works?
        Thanks for your message! Have you tried to run this script in Dynamo? If it have any warnings/errors or inputs required, it may not run. Could you confirm?
          Only run that one script so far which doesnt require any inputs. Will try others when i get some time and report back, but im guessing any script that requires user input would just run with the defaults?
          Bonus - i assigned a shortcut key to the script so i can run it without searching through tabs and buttons
            as I read that i imagine branching left/right from beneath the main ribbon button - that'd be really nice to bunch alike scripts together!
              Is there a way to have different scripts in the toolbar for different Revit versions, looks like they are now the same for every version and I have some that are different.
                No, the current version does not implement this feature.
