Has anyone worked out a way to get around the issue of sunlight leakage when doing dawn-to-dask sunlight/shadow studies?
Sunlight Studies (in Plan)
Originally posted by Munkholm View PostWhat do you mean by "sunlight leakage"? Do you have an example to show?
One view with view range from the roof down, one view (shadows off I think) with the floor plan you would like to show as reference. Put the shadowed one on a sheet, put the other one on top. Is that what you are looking for?There must be a better way...
Ekko Nap
*UPDATE*
Been a little busy with other things of late* but to keep this thread on it's feet - I thought I'd answer Munkholm's first question with an example...
....from Peter McCarthy's awesome Revit blog (image is a link) hopefully he won't mind, I'll apologise to him in person at the next LRUG if he does.
In essence, the image describes the "problem" perfectly. A shaded plan - where the view-range "cut" removes all (light blocking) elements above it - allowing light to "creep" in where it wouldn't.... look at the internal ensuite spaces, there'd be no (natural) light in that internal corridor - and yet Revit indicates that there would be.
True, I've not tried out ekkonap's method yet, so maybe the solution is out there, but seeing as this keeps floating around in the back of my head/to-do list I just want to keep it fresh for others to chew on.
*mostly job-related work, but also and experimenting with (practical) workflows for landscape modelling for our soon-to-start new (internal) appointment of a landscape architect.
Hi all,
Firstly, My name is Dave and this is my first visit here, i've been using auto cad for a few years and have now started to make the transition...December 14, 2013, 02:23 PM -
In Revit 2019, is there a way to "show in view?" Like the opposite of "hide in view?"
I have a plan that has a steeply...August 15, 2019, 02:43 PM -
i have a roof that after making some changes to the footprint said roof it disappeared in only one view (enlarged floor plan. I am able to see and select...December 12, 2017, 09:53 PM
i have heard there is a way of being able to visually see your view range settings, like you can select 'show' to see your reference planes.
can...July 10, 2015, 08:48 AM -
I have two views... a plan site view and a 3D view... both sharing the same still sun study settings and location.
Why are the shadows different?...January 29, 2013, 08:59 AM
