Hello family!
I haven't been able to find a solution from my query so I try to explain and see if someone is able to help me.
I am building a modular furniture system and I have the following issues.
family work).
- The system is built by components and modules. Each module is form by different components (as mechanical equipment {fix parameters} and structural frames and boards {flexible parameters}).
- For procurement purposes (report in schedules) I need to share every single component that form the modules. The problem is, flexible nested families can not be shared, as if so, they won't have their properties driven by the host family.
Does anyone have any idea of how to build this modules with either, be able to share in schedules their properties and also adjust their properties in the parent family?
I hope this make sense and I look forward to hear from you.
family work).
