Picking multiple elements
    I'm looking for a node that will allow me to pick multiple elements. I know that the OOTB node "Select Model Elements" will allow a box-style selection, but that's not want I'm looking for.
    I did notice this node in the Rhythm package:
    https://dynamonodes.com/2017/11/02/pick-model-elements/
    but for some reason that node isn't available for me. I have the latest version of the Rhythm package installed but that node isn't available.
    I'm running Dynamo version 2.3.0.6370. When I installed the Rhythm package there was a warning that the package was made for a later version of Dynamo. But as far as I know, I'm running the latest version. I'm using Revit 2020 and when I go to "Version" it tells me that Dynamo is "up to date."
    So, if I can't get Rhythm to work, does anyone know of another package that will give me this "pick multiple" functionality?
    Thanks!
    Hi there!
    This node was removed some time ago with the transition to Dynamo 2.0. More information about that here: https://github.com/johnpierson/Rhyth...movals-of-dyfs
    I plan to add a similar node back to the package with a C# replacement, but have not had a chance to get it done.
    For now, you can use the following python script:
    HTML Code:
    import clr
    clr.AddReference("RevitNodes")
    import Revit
    clr.ImportExtensions(Revit.Elements)
    clr.AddReference("RevitAPIUI")
    from  Autodesk.Revit.UI import *
    clr.AddReference("RevitServices")
    import RevitServices
    from RevitServices.Persistence import DocumentManager
    doc = DocumentManager.Instance.CurrentDBDocument
    uidoc=DocumentManager.Instance.CurrentUIApplication.ActiveUIDocument
    #offer the user the selection
    elementReferences = uidoc.Selection.PickObjects(Selection.ObjectType.Element, 'Pick model elements')
    #our list to append selection results to
    elements = []
    #obtain the elements via the id
    for i in elementReferences:
        try:
            elements.append(doc.GetElement(i.ElementId))
        except:
            elements.append([])
    OUT = elements
    John Pierson
    Creator of Rhythm, Monocle, Bang! and Lots of Other Okay Stuff.
    Twitter - @60secondrevit | Email - [email protected] | Blog - sixtysecondrevit.com | Work - parallaxteam.com
      This was removed a while back with the 2.0 transition and I have not added a C# replacement yet.
      More info on that here: https://github.com/johnpierson/Rhyth...movals-of-dyfs
      In the meantime here is the python to get you going: (copy/paste into a python node)
      https://gist.github.com/johnpierson/...842e7890c73f0f
      John Pierson
        Thanks John!
        • GetSurroundingElements Node Not Working
          Anyone have any ideas on why the get surrounding elements node would be failing me here in the attached script image? I know it use to work and it works...
          October 25, 2016, 08:23 PM
        • Spring Package Interference Check node does not work
          hey all ,
          the node in the spring package does not work in revit 2020
          does anyone has any idea why it is not working?
          and...
          June 13, 2019, 06:58 AM
        • Rhythm UI.UserMessage node
          I've got some versioning issues.
          I'm still using Dynamo 1.3.2 (need 2016 support)
          I had been on Revit 2018.2 & recently upgraded to...
          June 15, 2018, 03:23 PM
        • Clockwork Nodes Are amamzing.....but
          all of the sudden I do not know what is going on....
          My clockwork nodes are returning NULL...
          element.location is the first...
          January 18, 2017, 05:08 AM
        • Equivalent node
          Hey guys,
          I am having an issue, I am following a course and it requires the Documents.Builtincategories from clockwork. I can,t find the node AT...
          October 22, 2020, 01:19 PM
