beam is wider than the wall
    We have beams that are 10 inches in width. The brick wall is only 9 inches in width and does not line up to the beam. What do we do with the beam that is out? Chipping might expose steel. Any suggestions?​
    Welcome to the (Autodesk Revit-related) forum... is this a (real world-related) construction question?
    Whilst there are many talented AECO professionals here; your query might be better served elsewhere.
      Add a half inch of plaster/render each side - problem solved
      widgetinstance 211 (Related Topics) skipped due to lack of content & hide_module_if_empty option.
