Shared Parameters not exportable
    Hola,
    Hope all is well in this crazy world for you!
    I can't seem to Google my way out of this...the title block file attached has some shared parameters in it that I can't export.
    How do I get these parameters out??
    Thank you for your time!
    1. Do you have a Shared Parameter file active in that Revit session?
    2. Are you 100% sure that the SP file does not have that particulair parameter already in it.
    Both can be the reason the parameter cannot be exported. You can easily test that by just creating a quick, empty SP file and trying to export to that.
