Custom scale bar in Revit Setting
    Hi guys. i have some question regarding model Line weight scale. in Revit i know we can create a custom scale in the project. but in terms on controlling it in the model Line weight setting,under >manage/Additional setting/Line Weight
Name:	Line Weights.JPG
    is there any way to add custom scale in the list like 1:25/1:15/1:300?
    Revit Arch 2013 Certified Professional
    Phlippines Revit User Group
    Architecture | Structure | MEP
    International Order Of DeMolay
    Not to my knowledge no.
      When you use a custom scale the lineweight will be from the closest standard scale, so 1:25 will take the lineweights off the 1:20 , 1:300 will take it from the 1:200 etc.. and if its dead in the middle it takes it from the scale below, so 1:15 will take on the lieweights of 1:10, not 1:20.
      Quite easy to test...draw a couple of lines in a temporay project, change the scale to be non standard, change the lineweight list to be completly different for standard scales above and below that scale and see what happens
      Alex Page
      RevitWorks Ltd
        Thanks guys. i just thought maybe there's a workaround for this. any ways i hope they will include that setting for the future release. it will be a big help controlling the line weight in printing. regardless on what scale your using. i just want to be sure and accurate..
