Is there a way to have Revit automatically cut the portion of the roof out where the roof join/unjoin tool is used, rather than using the roof opening tool? a common example, is when you create a dormer. Most of the time, the portion under the opening wants to be removed
i have a few conditions where two roofs meet. It looks fine in plan, but it causes a lot of issues in section. I am hoping that there is a way in which if i use the Join roof tool, that it can remove the section that is joined. is there a way to do this, or do I have to do it manually?
