I was building a couple machines for a new project the other day and experimented with RFO benchmark to try out a couple things - mostly to figure out if I can go without dGPU on laptop.
The things I noticed is that 1) screen resolution has a measurable impact on performance; 2) Intel iGPU suffers from increased resolution a lot more than dGPU
Below is the summary of the full simplified benchmark, I picked a few of the screen setting below to run the full standard test to verify the result
i5-13600K at 5.3Ghz, 2×32GB DDR4-3200 16-18-18-38 with a freshly installed Windows 11 (22621.1105) on Revit 2020.2.3
Model Creation Benchmark
Graphics
the UHD770 performs mildly worse at QHD than on FHD, but the performance drop-off becomes much more noticeable at 4K (~25% slower on model creation and 80%+ slower on graphics). The GTX1070 fares far better when the resolution goes up.
Now I have to wonder, do Intel Iris XE or AMD Vega8 / RDNA2-12 on their APU do any better? Would anyone like to help test out these systems? Thank you very much!
FHD (100% scaling) |
QHD (100% scaling) |
QHD (125% scaling) |
QHD (150% scaling) |
UHD (100% scaling) |
UHD (125% scaling) |
UHD (150% scaling) |
UHD (175% scaling) |
UHD770 | 60.91 | 65.23 | 65.07 | 63.86 | 76.39 | 75.45 | 75.33 | 74.69 |
GTX1070 | 56.82 | 57.44 | 58.08 | 57.18 | 61.00 | 61.55 | 60.77 | 60.46 |
Graphics
UHD770 | 17.77 | 20.49 | 20.05 | 20.09 | 34.09 | 32.59 | 31.03 | 29.63 |
GTX1070 | 14.51 | 15.63 | 15.58 | 15.38 | 18.17 | 17.97 | 17.53 | 17.55 |
