I've created To and From shared parameters that have been added to conduits and fittings. We are using the conduit without fittings that are OOTB. The schedule does not automatically populate the To and From in the run schedule. It does populate in the conduit schedule. In the conduit run schedule the To and From has to be manually entered.
Is there a way to make this populate automatically? Dynamo, 3rd party add in, a native revit method? I have several projects starting up that are going to have thousands, if not tens of thousands, of conduits run between all of them. It would be good to have this running smoothly
