I want to create an instance of an HSS6x3 hollow structural section and I can't figure out how to control the rotation of the section. I want it to be 6" horizontal and 3" vertical rather than the other way around.
Rectangular structural steel section rotation?
This topic is closed.
What if you do the 1,2,3?
Edit type...
1) Duplicate
2) Rename
3) Invert the values of "b" and "h"
That's if you want another type. If you just wanted to rotate an instance:
Select the object > from the Properties window change the value of "Cross section rotation".Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
Originally posted by Alfredo Medina View PostWhat if you do the 1,2,3?
Edit type...
1) Duplicate
2) Rename
3) Invert the values of "b" and "h"I'm retired, if you don't like it, go around!
First time poster. I would like to know if it's possible to create horizontal sections in revit.
February 20, 2012, 04:48 PM -
Hi all,
I don't know what keywords to search, but if there is an answer somewhere, please point me there.
My question is:
I'm trying...-
March 11, 2020, 09:38 AM -
Hello,
Do sections have to be straight or can they jog, change direction, around. I can only seem to get them to be a straight line. ...March 12, 2011, 05:32 PM -
I have a drawing in which I would like to have two different section head types. I created a new section category (timber section) but this does not allow...January 14, 2016, 03:07 PM
When I cut a section at a certain level eg. @ Level 4, it doesn't appear and the warning comes out as attached.
I can see it at other lower levels...January 9, 2012, 08:49 AM
