Is there a way to rotate hooked anchors in baseplates? I prefer to see the hook rotate inward (180 degrees from default). The image is from a standard OOTB connection.
Rotate anchor bolts
NuriaTired, thanks for the tip. This works well on a single selection. With 100's of plates I was hoping for a global solution. I don't see the rotate option when editing the comnnection and I can't do a "select all in view" of just the bolts.
widgetinstance 211 (Related Topics) skipped due to lack of content & hide_module_if_empty option.
