I know that a material schedule will not pick-up the materials of wall sweeps. Is it also the case the railing materials will not populate a material schedule?
Schedule railing material
This topic is closed.
Yes. Railings are not available in a material take-off schedule. But there is a railing schedule available, which gives you fields such as "type" and "length" for every railing entity. You could add the material information in the "Type Comments" field, and if necessary, add more fields and calculated values.Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
No, they won't. Maybe if you create Panels using a Generic Model, make this shared and nest it into a Railing panel. And you don't use the balusters at all. But I'm guessing that would be a bit over the top...Martijn de Riet
Thanks for the confirmation. This issue (including the wall sweeps) is so weird to me. I can't figure out why they would leave this out of the material schedule?
Our office schedules all the finish and misc. materials in the project: paint, base, countertops, flooring, casework, ceilings, etc. It makes sense to me that if I place an element in the project and I will need to know what its material is, I will want to schedule it. So when I place my wall base as a wall sweep and it allows me to define a material for it, I would expect that it shows up in the material schedule. Now I have to do some work-arounds to make it work. Blah:blah:
Ladies & Gentlemen,
Should materials be named for their assets or the thing they’re applied to? I like the idea of a material being...January 16, 2017, 08:37 PM -
Hi guys,
Has anyone had a problem with railing schedule? For whatever reason it doesnt really group it together. The list does get somewhat...-
June 3, 2016, 02:27 PM -
I set up a schedule in which I am listing the materials and their properties, etc. Some walls have the material repeated (for example 2 sheets of plaster)...February 8, 2016, 08:05 AM
Hi lady's and gentleman,
I have a question regarding scheduling. I'm wanting to produce a schedule that shows the wall make-ups (i.e. plasterboard,...October 2, 2015, 09:43 AM -
We have many multi story railings on a project. They are all scheduled as one instance with the length of the base railing. In other words, if I have...May 12, 2015, 03:37 PM
