Hi all, I am using Revit 2022. I have a balcony which repeats over 20 floors. I'm modelling it partly with a floor, a generic model family to form some funky shaped cladding and then a railing to the edge. As it repeats 20 times I want to combine everything into a model group.
I add the floor and my generic model family and it works absolutely fine. But as soon as I try to add my railing into the group, it comes up with the dreaded "Fix Groups - Group instances of the same type do not contain identical members". My railing isn't particularly complex, the path has curved corners but apart from that it's a pretty standard rail with a rectangular balustrade on top. If I draw the rail as a straight run of 100mm long, it adds to the group fine. But as soon as I model the path I want and add to group, computer says no!
I've tried deleting all instances of the model group, I start from scratch by adding everything into a new group and as soon as I copy it up to the level above, I get "Fix Groups". I've also tried doing a model group which only has the railing in and it won't even do that. Can anybody suggest anything please? Is there a way that I can have a railing embedded within my generic model family? If I could incorporate it into the cladding family it should work OK but I don't want to have to model all of the posts individually. The standalone rail in the Revit project is perfect, it just refuses to add to the group 😬
