Hello Guys,
I exported the Ifc file with magicad but I have problems with coordinates when adding IFC files from Magicad in Navisworks. Let me explain, on revit I am working with shared coordinates and everything works fine but when I export the ifc with magicad the MEP LINK is not in the correct position.
I also followed autodesk's advice but it doesn't work.
https://knowledge.autodesk.com/suppo...m-Magicad.html
The revit version is 2018.
Thank you all
