show hidden line of the balcony in the floor above
    there is any automated way that revit can show the line in red in floor plan
    im mean that revit will show the hidden line in ground floor of the balcony above that located in the 1st floor
    Last edited by LeanneZ; June 11, 2020, 01:10 PM. Reason: edited font formatting for better readability
    Not automatic, but easily doable. To just show the line, turn on your overlay, then use the line work tool too pick the lines of the balcony you want to show. You can create a line type first if you want it to be red. Turn off the overlay and the line work of the lines you picked with the line work tool will be visible.
    If you adjust the balcony later, it will update (as long as you don't actually delete that sketch line when you edit the balcony).
    Dan
      oh that's great ! thanks a lot!!!:laugh:
