Hi All, I’m wondering if anyone could help me, I have loaded a building into another revit file which also had a site surface associated with it, is there any way to turn off the site in the linked revit in the building file so that only the building will show? I am using revit 2012 if that helps in any way.
turning off individual items from linked revit files
tab through until you can select the items you want to hide, right mouseclick, hide in view?Martijn de Riet
In VG select the RVT Links tab. Click on your link and select the Custom button. Select Custom again then move to the Imported Catagories tab.
if that dose work.
Try tabbing on the linked file untill you select the site surface. You can then EH or Element Hide.
or
in VG try turning off the 2nd linked file in the Revit Links tab.-Alex Cunningham
Hi all thank you for your help, that was all very helpful, I looked and had a played with a few settings and was able to go in to In VG select the RVT Links tab. Clicked on your link and select the Custom button. Select by linked view and changed the linked view to 3D view, then I had to go into the VG of the building file and turn off the typography VG then loaded it back into the revit file and that worked. Thanks once again
A quick one:
Is there a way of turning off the snap, but only to linked files (acad)?April 5, 2016, 10:24 AM -
Hi all,
I cant select a linked .dwg file that Ive linked for use in my site plan drawing, normally I can select these files to query lines...September 15, 2014, 04:04 AM -
Hi everyone
I am an architect and linked mep to my revit file
we have "exhaust fans" and "Packaged Water Chillers"...May 23, 2012, 06:53 AM -
I have a linked Revit MEP file that includes clearance zones around some of the equipment.
I need to be able to turn these off in some...February 21, 2016, 05:34 PM -
Hi, So I have our main model with some other models linked in.
the other models are buildings adjacent to the main project building....December 21, 2010, 10:12 PM
