Level and Grid visibility with Scope Box
    I can see the benefits of tying my Levels and Grids to a Scope Box around the building. This ensures my Level and Grid markers are consistently placed in my Plan and Section views. This is good.
    However, if the cut plane of an Elevation is outside the Scope Box, then my Levels and Grids do not show. Is there a way to make them show please?
    Thanking you.
    Don't worry. I think I just figured it out:
    * Go to a view where the actual Scope Box is visible and select it.
    * Under Properties > Views Visible, hit Edit.
    * Find my desired elevation view in the list.
    * Change the Override column from None to Visible.
    Thank you!
