Plz Help me .............Elliptical walls
    Hello Everybody
    I`d like to draw an Elliptical walls and make trim to to some parts, I did it by drawing a mass and assign wall by face but i found problems in trimming some parts of walls and some junctions not good Plz help me.......... Jpg file attached
    Hello anybody there to help me
      Just deleted the duplicate posts in other threads... You'll get a reply soon enough, if you'd just show a little patience.
        Split lines doesn't work?
        btw: dude, chill . We have work to do too you know. Getting very impatient after 20 minutes or so doesn't help...
          Are you having trouble getting the ends of the walls to clean up with the elliptical wall? Or am I misunderstanding your question?
          You can drag the ends of the straight walls until they intersect the elliptical wall, and when you let go, they should clean up automatically. If they don't, make sure you don't have the straight wall ends set to "disallow join". Select the straight wall, right-click near the end grip, and make sure that it doesn't have an option to "allow join." If it does have that option, select it.
          Arcturis
          BIM Manager
          Associate Architect
            Sry if i Disturb you ...... but i tried to split the Ellipse and create a wall by pick line but didn`t select .
            I did the Elliptical wall by creating a spline and from massing (mass in place) and assign a wall to the extruded Ellipse by picking the face. Is it true???
              Ellipses are just a pain in the arse, as David Light so nicely put it Have a look at this video from his blog, and also have a look at some of the blog posts linked below.
              http://autodesk-revit.blogspot.com/2011/08/revit-2012-dept-of-unfair-ellipses.html
              http://whatrevitwants.blogspot.com/2011/08/turn-ellipse-into-arcs-for-use-in-revit.html
              http://buildz.blogspot.com/2011/08/s...g-ellipse.html
                Thx rosskirby for ur Interest
                Sry rosskirby u didn`t got my point
                first......I want to know the proper way for creating Elliptical Walls intersects with walls
                second.....if i did the elliptical wall by creating it by massing how can i use trimming and split to open in that elliptical wall as on may Dwg i tried to split by face and trimming doesn`t work
                Third......my straight walls end when intersects with elliptical not clean up automatically.
                  Thx u Munkholm very much
                    As you've already experienced, elliptical walls created by a mass can not be trimmed.... Best option IMO is to create the "ellipse" as a series of arcs, which will be trimable, and also a lot easier to document for construction. Good luck with it, and welcome to the forum.
