Titleblock scale - parameter that halves the scale
    Hi smart people!
    I'm setting up an A1 sized titleblock - I've used the scale label to show what the scale will be at the original A1 size. I'd like to find a second label that halves that scale; i.e. shows the scale it would be if printed at A3.
    Does anyone know how to make a label that would halve the original scale?
    Thank you!
    Don't think that can happen automatically.
    Better to tell people some that the print is scaled, I have seen people use a small 3 square icon (1x3 cm) in there title block with the text that it should be 1x3cm or else it is a scaled drawing
      The views only have one correct scale. The use of graphic scales might help avoid this issue.
