To create GAS supply, du we use pipe or duct connectors?
    thanks in advance
    Not sure if GAS is an acronym for anything, but if it's just gas (as a form of state of mater), then normally you use pipe systems.
    Terms can be a bit misleading though. So for exhaust systems we use generally ducts. Exhaust is also technically a gas, but in industrial environment when you say gas it means in a pure form (element, like H2, N2 etc) or a mixture for production. And it's usually pressurized to keep it in liquid state, thus you use pipes for it.
    I hope i didn't get you question wrong
    MEP CAD / BIM technician - @MatevzPetric, LinkedIN
    Trying to learn something new every day
