symbols for tagging...
    hi
    i discovered today that it's possible to add a symbol OR (may be and, don't know) a tag
    in found this option in loaded tags...
    so i was wandering how can it be used (i don't know yet how to use it)? have you any example of this kind of "annotation"?
    why do you use it?
    try to find some help on internet but ...
    thanks
    Phil
    Freelance WWTP/HVAC Designer
    Revit 2019
    When you have multiple tags loaded into a project you can set the default for that category.
    I've never set the symbol before.
      hello,
      as this crazy man Napoléon, said:
      "a picture is better than a long speech" (nt sure of the english translation)
      thanks
      Revit 2019
        I'm curious, how did you get to that dialog box?
          Ah, I found it on the Annotate Tab under "Tags"
            But how does it work?
            Envoyé en utilisant Tapatalk
            Revit 2019
              I actually have no idea what that Symbols Column is for. I would have guessed MEP? For things like Pipe Verticals? But i cant see a way to use it.
                Some structural elements have documentation symbols in addition to tags (span arrows, etc.). For those elements, there will be a tag and a separate symbol family you can load. Other elements might utilize it too, but I haven't played around with it (or need to).
                  Gosh, even the great twice doesn't know the answer!
                  For pipe and duct there is a option for their representation... but I'm a dummie...
                  Really weird!
                  Revit 2019
                    It can be used for rebar shapes.
