NEW RELEASED NonicaTab. Deploy and share Dynamo scripts as Revit buttons
    Deploy your Dynamo Scripts in Autodesk® Revit® like a PRO!
    NonicaTab PRO creates a new Revit toolbar with 3 profiles of 12 buttons each easy to customize with your Dynamo scripts and favorite icons. Profiles (Default, Beta, and Gamma) can be easily switched at runtime to use different sets of buttons.
    The PRO version also allows you to import and export your NonicaTab PRO toolbars and share them easily. A file (.nonica) will be created in your selected location which you can use to import in as many computers with NonicaTab PRO installed as you wish.
    What about the Dynamo packages? FORGET ABOUT THEM! If your Dynamo scripts are running well on your PC, they will run well in the importing computer. When you export your toolbars, NonicaTab PRO detects all the installed Dynamo packages required to run the scripts in your toolbars and they will be imported together with your toolbar. You only need to make sure that they are created or resaved in a Dynamo version later than v2.3.
    If you prefer to set up your own icons and scripts, the PRO version also has some features that you will love;
    • Refresh All. Update all Dynamo scripts in your NonicaTab buttons in one click . All you need to do is to keep your modified Dynamo script in the same location with the same name as the selected button.
    • Icons. Select any jpg or png image of any size and it will automatically be converted and included in your NonicaTab button. Extra set of icons of different colours included.
    NonicaTab PRO runs Dynamo in the background and pops up any input window such as Data Shapes package input nodes. NonicaTab notifies in real time if the script was run successfully or with errors or warnings. You can also set your Dynamo scripts to run from keyboard shortcuts!
    This new version is published in Autodesk App Store. Attached you can find the link;
    https://apps.autodesk.com/RVT/en/Det...ng=en&os=Win64
    Nonica team is committed to its clients and users. Please, contact us [email protected] if you have any doubt or need help to set up. We would be glad to help.
