Revit Rounding Issue
    I encountered a rounding issue and hope someone here can help me.
    The scale bar below shows two 1' among which the left 1' should be actually 0.5' but it's been rounded automatically. All these numbers are driven by family parameters but I couldn't figure out how to make them show up properly in project. Thanks.
    It looks like it is getting the rounding from the project settings. If you open the family and edit the label, you can change the rounding of each parameter to be something different: (and I would assume youll want to suppress traliing 0's)
    Alex Page
    RevitWorks Ltd
      Thanks, Alex. You saved my life.
        If your Project Settings are rounding to the nearest foot, that Graphic Scale is going to be the least of your problems!
        Dave Plumb
        BWBR Architects; St Paul, MN
          The problem is not with the project setting, instead, it's the label formatting issue - Labels were set to use decimal feet but rounded to 0 decimal places.
