Tags Info Incorrect for Grille Family
    I am having some issues with tagging the a grille family and having it display the correct information. No matter the size and flow of the grille, it always displays 12"x12" and 0 CFM. I am fairly new to Revit and while I've tried to figure out how to change it so it shows up properly, I haven't been able to figure it out. Can someone please explain why this won't work and what steps are necessary to fix the family so that the tag shows up properly? I've attached the tag and grille families. The tags work for every other grille I have except this one.
    Thanks in advance!
    -Nar
    It is because the grille family's connector "size" is not associated with the air terminals size. Edit the family, select the duct connector, assign the width and height values (by selecting the "button" to the right of them in Properties) to Width Custom and Depth Custom parameters.
    John Karben | IMEG Corp.
      That worked! Thank you!
      -Nar
        So I have a similar situation with the attached family where my diffuser's size says the connecting duct diameter (neck diameter) but not the square size of the diffuser. Since the duct connector is a circular one in the family, I'm not sure how to assign it so that the same tag in the OP shows the correct size. Any thoughts?
        -Nar
