Trouble Loading Arch model in BIM 360.
    Hi All,
    Trying to link arch models from the consumed folder on one of our projects. It says failed to open.
    Few things: Architect given us permissions
    Using the same Revit version.
    What could have been wrong ?
    are you linking to the file in your team's folder under the consumed folder?
    Scott D Davis
    Sr. AEC Technical Specialist
    Autodesk, Inc.
    http://bit.ly/aboutsdd
      Actualy what I'm trying to do is,
      Linking the arch model from arch's consumed folder into our services model which is not consumed i.e. we were working on live models and we were suppose to share the models each two days.
      Attached screenshots First one why i can't see any of arch models even after consuming.
      Second screen shot what I can see on architects doc management consumed folder these had updated by me .
        I'm a little confused by the 2 screen shots. Are these on 2 different users machines? One from "services" team, and the the other from the "architectural" team? This may require some help from support, ether from Autodesk or your reseller, just so we can do an online screen share to see exactly what's going on.
        Scott D Davis
        Autodesk, Inc.
