Steam Nodes Issue
    Steam Nodes Issue
    Hi Everyone.
    I'm using a node from the Steam Nodes package called Schedule.GetCalculatedValues. It accepts a Schedule View and a Schedule Header as its input and extracts the Calculated values.
    It looks like this package hasn't been updated in some time, and when I upgraded to Dynamo 2.x, this node started throwing the following error. Strangely, it still works, but it does cause the "Run Completed with Warnings" message. I'd really like to make that message go away.
    When I try to edit the node, I see this message:
    In the editor, I see this. As you can see, it was written for Dynamo 1.0.
    Both of the red input nodes are throwing this error.
    I know nothing about Python.... is there a simple edit I can make to make this node work correctly?
    Thanks!
    1. It look like if you change the input fiels to just ViewSchedule and CalcVal is schould work (You do need to double check if ViewSchedule is not a reserved term)
    2.I would do some more research on Dynamo Forum and the package manager to find a method to get your Calculated Values, since Steam is so outdated atm I would just not install it anymore.
      That did the trick! Thank you!
