Make a component family with System Category
Author of What Revit WantsTags: None
Yeah... Theyve had a family template made by using that method, at this office since before my arrival. Ill tell you what i would do: Get rid of it immediately. They cause serious stability issues. They get erratic if things are hosted to them, they delete things, they cause errors and hiccups when a journal has to report a *category* for the family, and all sorts of other weird stuff.
Totally not worth the investment.
Originally posted by Twiceroadsfool View PostTotally not worth the investment.
It is one of those hacks that might be super-useful in certain situations, but you would have to be very careful with it. I'm glad I put a disclaimer on the original postLuke Johnson | Autodesk Expert Elite Member
Dave Baldacchino had first posted this hack some years ago in AUGI, and I have messed with this hack just to see if it was worth using in a project. I did made a wall family and used it in a project, but you won't be able to host any doors or windows.
Kind of like what Aaron said, it is unstable. I also made a ceiling family using the same trick but it had some weird behavior as well; of course ADSK will not support this either.
I am not sure this will be any different in 2012.
I don't use Revit nearly as much as most of you do here, so I don't dig quite so deep into the program. I have noticed one thing that has always happened,...February 17, 2015, 12:51 PM
What Revit Wants: Save an In-Place Family as an RFA for use in another project
Other than putting users on the wrong foot in dealing with...June 14, 2015, 07:59 PM -
Fellow Expert Elite Karam Baki has posted an interesting workaround for 'converting' between differently hosted Revit families. The term converting isn't...
Channel: Blog Feeds
January 30, 2017, 12:45 AM -
I have created a generic family model of a suspended acoustic baffle. In the project, rows of these elements are used to form the ceiling.
...July 5, 2016, 12:08 PM -
So I have been trying to learn a lot about my ancestors...about where we are from and such. I know that by blood I am German but throw in some Scottish...
Channel: Out There
December 7, 2011, 03:50 PM -
