Help with lookup table and formula
    Hello,Please look at attached. I don't know why revit is not taking value from lookup table, but only 'DefaultIfNotFound'.
    Thank you
    Try to make the column names match the parameter names or vice versa.
      Originally posted by Nurlan View Post
      It's not working. I changed parameters name to match columns, cause when I try to change columns name and put it in formula it gives 'invalid input' nonsense.
        The names and type of parameters must match the lookup table.
        Your formula is looking for a match of two values (ND1 and ND2) in a row, if there is no match, then the default value is substituted.
