hi, anyone got this problem before?
it is like this: i put in a steel column on grid, draw a reference line at 5 degree from the column, then draw a steel beam follow the reference line...make a steel portal frame. then i go to 3d view, pick the top flange as the workplane to draw roof purlin in, but sometimes the workplane is in a angle, it is still top of the flange, but the workplane's grid is not square to flange edge
i hope i've explain clear enough?
here is an example of the rotated workplane of the portal frame
anyone came across the same problem?
here is an image
set the workplane to top of the flange, and it is rotated. why?
here is an image
