Hello All
Need your expert guidance. At my wits end at the moment:banghead:, I need to deliver a tender package next week and the dwg files just cant seem to stay put, even thought its pinned.
To give you a brief of the issue
We use linked CAD dwg files for our site related drawings, instead of modelling in revit. At times the dwg file stays in place for a few days, months even... and then it decided to move of its own accord. This can happen either at the time of reloading the dwg file or sometimes after opening the revit model with the linked dwg in it.
I have tried to make sure that
1. the linked dwg file isnt open when reloading into revit or the revit model isnt open when editing the dwg file.
2. when reloading the dwg file, I make sure i use the view used initially with the same orientation.
I even created the Site seed file from the OOTB revit template (just to make sure there wasnt anything in our office templates that could be causing the discrepancy.. but no luck). I have attached our workflow in the attachments. Please could you advise where I am going wrong and help me so that i dont have to keep redoing all work again and again..
Appreciate your help...
Thank you
Kay
Thank you
Kay
