Dear colleagues,
I've got a problem with my central file in my company:
When I want to open the central file and get an local file for working, it can be that Revit opens the central file itself and doesn't wirte an local file.
I can see this in the WSM and on the name in the Revit-Menu.
Also, when I want the for example move a window in my plan (also a command that have nothing to do with the Modell itself) the error, that the central Modell is in use and the command can not be finished, occurs.
I have unfortunatly no idea what caused this Problems - I also don't get an answer in AutoDesk-Help...
Maybe some of you know this problems or know what I can do.
Thanks in andvance for your answers!
Best regards,
Matthias
Best regards,
Matthias
