Hi
I have iritating issue in Revit. I made a section of concrete reinforcement bridge. "View range" of section is 0mm, because I just want to see only a thin slice. I cannot make dimensions of arc, also it is not possible to make horizontal dimension between vertical walls. Anybody knows why? Why revit do not want to use edges, that are exactly in this section? I attached .rvt file. In inventor it was completely not a problem to make a dimensions of exges in section. Revit do not see section edges? In a picture below example dimensions that I am not able to make. I know that I can make a detail line and it will works, but I don't want to, because that cost time!
Thanks in advance.
Thanks in advance.
