Structural Concrete column parameter formula
    I create a concrete column family and i want create a length formula parameter will depend of yes / no parameter for make a side column position. The reason why i want this is for the culomn schedule. If i said yes to side parameter, i need the dimension to "0". If the side is no, I want the dimension of half pilaster width.
    I don't know how to make the formula.....:banghead:
    I join 2 img. for help.
    Thank you
    If I understand your question, you should write something like this:
    L POSITION=if(SIDE_L,0,DEMI COLONNE L)
    You didn't give what you want with W POSITION, but I think you can figure out from this.
    With a yes/no value, you just write the name of the parameter. If you want to invert the value use not(PARAMETER).
    The format of an if statement is this:
    IF (<condition>, <result-if-true>, <result-if-false>)
    Read more about formulas: https://www.revitforum.org/showthrea...day-quot-usage
      Thank you, that work!!!!!
