Hello I fairly new to making objects in the Revit Family editor.
So if anyone can explain what I am doing I would be very grateful.
I am making a bespoke window and having quite a few problems.
I intended the window to be truly parametric so that I could create several in my building, with different dimensions but similar geometry.
Some I thought would be 1700 high by 2000 wide and some 700 high by 2000 wide.
Using the window template I created a Revit family file with the following parameters.
Glass side panel –created as instance
Glass top panel – created as instance
Height – came with template file
Mullion height – created as instance with formula
Width – came with template file
I can insert file in architectural project. Several problems arise.
Firstly, only parameters available, which I assume count as instance parameters are:
Glass side panel –can be altered
Glass top panel – can be altered
Height and width are only accessible if you click edit type. So if you change one you change them all. So am I right in thinking height and width are always fixed in most family types or is that all
The only things that can change are things like number of window bars, an instance controlled by visibility parameters and the use of rotation parameters to control things like openable window panes?
Height and width never change?
And head height and sill height can be adjusted for each instance?
Another problem is when I drop in this bespoke window, Revit temporary windows are not appearing. Which means I cannot place it with any accuracy.
I have read that Revit sometimes turns off temp dimensions when wall structure is complicated and you have to go to green toolbar to click activate dimensions.
Sometimes it is necessary to select several items using ctrl key before activating dimensions. Tried this approach and it did not work.
Any idea what I am doing wrong?
I enclose file created in Revit 2016.
Thanks for all help received.
